HPDxxx
| posted on 20/1/17 at 02:04 PM |
Pinion seal - fisher fury live axle
Hello guys,
my fisher need a new oil seal on diff pinion.
i have take off old one and here you can see some photos and numbers i have found.
i have found on ebay this: CLICK HERE
but he let me dosn't match measure...
do you know if this is the right one?
CLICK HERE
i have sent en email with photos and measure but i haven't received reply.
i'm located in italy and i don't want order the wrong one..
thanks for help
MikeRJ
| posted on 20/1/17 at 03:06 PM |
Your car uses the Ford 'English' axle so that would be the correct seal for it.
Hopefully you accurately counted the number of turns on the nut when you removed the flange so it can be done up to exactly the same point again. If
not you should replace the crush spacer and reset the pinion preload.
[Edited on 20/1/17 by MikeRJ]
HPDxxx
| posted on 24/1/17 at 07:46 AM |
thankyou so much for your help and input.
i have place an order i hope will be here soon.
