Hammy360
posted on 7/3/17 at 08:36 PM |
Chester Sportscars Carb Kit
Hi,
Has anyone fitted the Chester Sportscars bike carb complete kit with Ignition etc. Wondering if its plug and play and how much the kit is these
days.
Hammy
Ugg10
posted on 7/3/17 at 09:38 PM |
Had one of the earlier ones with megajolt (now use nodiz) on a stock 2.0l silvertop. Easiest thing ever, bolt on the manifold/carbs which were pre
jetted and ecu preprogrammed. Just hook up the five or six wires and off you go, set the idle and run all day. The next owner had it rolling roadbed
at 165hp, can't be bad. Iirc it was about £1k all in.
You will need either a bike fuel pump or I used a facet posiflow pump with a low pressure regulator, the bike carbs need about 2psi (a lot less than
Weber).
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
Hammy360
posted on 3/6/17 at 12:26 PM |
Thanks mate, very interested in these
Hammy
Jenko
posted on 5/6/17 at 07:24 AM |
What engine?....if it's already fuel injected, I would go to ITB's
MY BLOG - http://westfieldv8.blogspot.co.uk/
