joneh
posted on 8/4/17 at 08:00 AM |
Alfa GT stiff clutch.
Hi All,
Any suggestions on my mstes Alfa GT JTDM 1.9 - it has a very heavy clutch pedal? Been like it for 3 years, from 30k miles so don't think it
needs a new clutch.
Most garages seem to want to fit a new clutch. Forums suggest it seems to be a sticking release bearing or clutch fork getting stuck in bushes.
Thanks!
Jon
posted on 8/4/17 at 09:44 AM |
Is it worth taking the box out to sort the heavy clutch without replacing the clutch? If it was mine I would fit new!
ian locostzx9rc2
posted on 8/4/17 at 11:21 AM |
As said remove gearbox make sure it's all free and replace the clutch
joneh
posted on 8/4/17 at 11:34 AM |
Yeah I see your points, looking at the forums some suggest you can grease it without removing the box. Just wondered if anyone had any tips or a
similar issue.
perksy
posted on 8/4/17 at 12:38 PM |
Is it cable or hydraulic actuation?
joneh
posted on 9/4/17 at 10:51 AM |
I'll check with him... I assumed cable.
joneh
posted on 10/4/17 at 08:12 PM |
Ok it's hydraulic....
posted on 11/4/17 at 07:19 AM |
If it has an external slave and visible linkage it may be possible to lubricate any visible linkage but if that doesn't work
then it's likely to be box out
