femster87
posted on 13/5/17 at 09:20 AM |
Smooth power transfer to diff
Struggling to get power transfer. To diff without a knock. As anyone fitted the rubber donut to help reduce the knock.
adithorp
posted on 13/5/17 at 09:28 AM |
Knowing from what engine/box might help.
http://jpsc.org.uk/forum/
femster87
posted on 13/5/17 at 09:54 AM |
Zetec, to Mazda gearbox and sierra diff
Sam_68
posted on 13/5/17 at 10:12 AM |
With those components, in good condition, you should be suffering undue problems.
Are you sure there's not a clearance issue, somewhere? Or play in the propshaft UJ?
femster87
posted on 13/5/17 at 10:23 AM |
I looked at the diff mounting yesterday and it looks secured. The prop bolts are all tight and seem to be in good nick. I'll have to set up a
camera under the car and go for a drive
Nickp
posted on 13/5/17 at 10:59 AM |
Backlash in diff?
femster87
posted on 13/5/17 at 11:10 AM |
That was my initial thought, hence the rubber donut to take out the slack
Nickp
posted on 13/5/17 at 11:30 AM |
You need to fix the issue not try to mask it IMHO
A rubber donut won't take out the slack it'll just soften the clunk maybe.
Fetch it round here (Wombwell) and we can take a look if you want? I'm currently playing with diffs
[Edited on 13/5/17 by Nickp]
femster87
posted on 13/5/17 at 11:43 AM |
Nick, should I call round tomorrow and we can go for a drive, you'll see what I mean. Diff is only 3 years old.
Sam_68
posted on 13/5/17 at 11:56 AM |
Is it more of a clunk, or a knock (don't you just love trying to diagnose noises on the internet)?
If the former (duller, because it's inside a casting filled with thick gear oil and mounted on resilient bushes), diff backlash would certainly
be prime suspect. If it's harsher, spider on the UJ or the gearbox or diff knocking against the chassis due to inadequate clearance would be
favourites.
Has it always done it, or is it a noise that's developed recently?
femster87
posted on 13/5/17 at 12:03 PM |
It is more of a clunk. just put car on the road yesterday after some winter work. Not on the driveline though . New owner and not driven since
purchase.
Nickp
Yeah I'm about in the morning mate I'll u2u my address.
femster87
posted on 13/5/17 at 12:10 PM |
I know your place. came round to drop head light last time
Nickp
posted on 13/5/17 at 12:29 PM |
Yes mate thought you did
britishtrident
posted on 13/5/17 at 01:55 PM |
Brake caliper taking up lost motion in the slider ?
[/I]
madteg
posted on 13/5/17 at 02:46 PM |
I have always had a knock. Reconditioned Diff.propshaft.driveshafts and gearbox .
I have put it down to backlash in diff and also everything is solid mounted.
Just live with it now as its pnly noticeable when in traffic. Please let me know if you sort it out
femster87
posted on 14/5/17 at 06:08 PM |
For continuity, the diff has a lot of backlash in it. Will wip it out and get it adjusted. Thanks Nick for the help
[Edited on 14/5/17 by femster87]
