Barksavon
posted on 30/6/17 at 11:02 AM |
ST170 a engine Identifiable
Does anyone know whether there is a surefire way of visually confirming a ST 170 engine is a ST 170 engine.... Probably going to buy a 2nd hand one
thats not still in the car and don't want to get 'had over'
Ian
Ugg10
posted on 30/6/17 at 11:25 AM |
Only zetec engine (exhaust on the passenger side, iron block when in UK RWD config) with a vct valve in the head. Also has a unique rocker cover which
says duratec on it (a bit miss leading).
[Edited on 30/6/17 by Ugg10]
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
big_wasa
posted on 30/6/17 at 11:36 AM |
The rocker cover is unique so is the vvt solenoid just behind the cam pulleys.
There are a lot of these being broken at the moment so they are not rare enough to pass of as zetec as an st.
Regular oil changes are more important than mileage but both is nicer still.
Barksavon
posted on 30/6/17 at 11:37 AM |
Cheers guys
Ugg10
posted on 30/6/17 at 11:58 AM |
Zetec egnines -
Early Silvertop - Ally head, iron block, single piece ally sump - (note - fitted with log plenum)
Black top - Ally head, iron block, two piece ally sump -
Zetec St170 (badged duratec) - similar to blacktop but note the different cam cover and the bulge near the can sprockets for the VCT valve (Note
fitter with aftemarket exhaust and bike carbs)
if the block is alloy then it is either a Zetec SE (yamaha designed) or true Duratec and not a Zetec (silver/black or ST170).
Barksavon
posted on 30/6/17 at 06:56 PM |
Brill thanks for the pics , if I can get my engine looking as nice as any of those will be well pleased
Ian
