Author: Subject: exhaust - do I need the flexi?
craigdiver
posted on 7/8/18 at 03:30 PM Reply With Quote
As per the title, do I need the flexi or are the exhaust mounting rubbers sufficient?
If it ain't broken, fix it anyway (just because).
Building - BMW powered Haynes Roadster/442E hybrid.
Volvo C30 T5 Polestar
posted on 7/8/18 at 03:37 PM Reply With Quote
No flexi on my MK Indy, just a rubber mount at the rear of the silencer. Never had any issues with it.
craigdiver
posted on 7/8/18 at 03:42 PM Reply With Quote
Thanks Nick, was going to support near the cat then at the rear of the silencer but you have got me thinking now if two mounts
are needed, hmmmm
posted on 7/8/18 at 03:52 PM Reply With Quote
Mine has just a single mount at the rear , have had no problems in at least 12 years . Make sure the engine mounts don't have too much flex , fit an engine steady if needed.
myke pocock
posted on 7/8/18 at 03:59 PM Reply With Quote
Well that IS a surprise. I would have thought flexi all day but just goes to show what I know!!! (or dont)
posted on 7/8/18 at 04:09 PM Reply With Quote
are needed, hmmmm
I must admit that my exhaust didn't have (or need) a cat in it.
snapper
posted on 7/8/18 at 05:57 PM Reply With Quote
It’s all about engine movement so you need firm engine mounts as stated and possibly an engine steady but I’ve not needed one.
Counter intuitively a single slightly flexible exhaust mount near the back of the silencer is better than 2 mounts as the forward mount becomes the point at which the manifold and down-pipe will pivot, then you would need a flexi
I eat to survive
I drink to forget
Nickp
posted on 8/8/18 at 05:37 AM Reply With Quote
No flexi on mine either, just a single rubber mount under the silencer. I have Land Rover engine mounts and a steady.
My silencer looks a fair bit bigger than yours (27" IIRC) and was still just under the noise limit at IVA.
Also, what's your plans for that CAT? As there's a lot of sharp edges on it.
[Edited on 8/8/18 by Nickp]
craigdiver
posted on 8/8/18 at 11:43 AM Reply With Quote
Silencer was cheap, was hoping I would have room for a second that could be put in line to reduce db if needed. The cat will be wrapped in exhaust wrap to keep it nice and hot (and cover the sharp edges). (going to round off some of the sharp edges too)
[Edited on 8/8/18 by craigdiver]
loggyboy
posted on 8/8/18 at 01:08 PM Reply With Quote
Depend son how firm the engine is and if the exhaust isnt solidly mounted to the chassis.
If you have a very firm engine it shouldnt be needed, if there is engine movement you want to match that with exhaust, either with the flexi or have a reasonable movement in which ever rubbers you mount the exhaust it on.
Mistral Motorsport
