steve m
| posted on 11/11/18 at 12:59 AM |
OBP leak/problem
Hi all
Ive got an OBP brake pedal box, and I have a leak!
To start with, the leak, was a drip every few weeks from the front master cylinder, and annoying, but nothing more
So I took the resovoir off, and seals , cleaned it up, ( wasn't dirty) and put back on
Leaks worse now!!
order new resovoir kit, put on, leaks the same, badly,
so, have I got a bad master cylinder ?
Im only asking, as this is really doing my head in, as its so simple, but also so taxing
steve
| posted on 11/11/18 at 09:45 AM |
Which type of master cylinder and where exactly is the leak coming from?
steve m
| posted on 11/11/18 at 07:04 PM |
Its one of these, with the separate resovoir
https://uk.images.search.yahoo.com/search/images;_ylt=AwrJS9eke.hbgGYAAM1LBQx.;_ylu=X3oDMTE0amQwOTZkBGNvbG8DaXIyBHBvcwMxBHZ0aWQDQjYxNjhfMQRzZWMDcGl2cw
--?p=obp+cylinder&fr2=piv-web&fr=yfp-t#id=0&iurl=http%3A%2F%2Fwww.burtonpower.com%2Fmedia%2Fcatalog%2Fproduct%2Fcache%2F1%2Fimage%2Fdbee39
002c3ed3c5438224ee0989910f%2FO%2FB%2FOBPCB001.jpg&action=click
Today, ive taken the resovoir off, dismantled again, cleaned, and put together, made a blanking plug for the bottom, and filled up with brake fluid,
and so far no leaks,
Next day off, I will put it all back together on the car, and if it still leaks, it has to be the master cylinder
steve
Tonesta
| posted on 11/11/18 at 08:29 PM |
I had the same happen to my obp pedal box rear master cylinder however I replaced the master cylinder and never resealed the old unit.
New unit has been fine no leaks
steve m
| posted on 11/11/18 at 10:59 PM |
Thnks, at least is shows im not mad !!
steve
| posted on 12/11/18 at 08:51 AM |
Can't get the link to work. Do you have a remote or cylinder mounted reservoir? How is the reservoir connected to the MC? Do you have the
correct fittings? Is the leak from a high or low pressure part of the system ?
Mr Whippy
| posted on 12/11/18 at 12:36 PM |
In the old days I'd have just changed the seals but these days, brakes...new cylinder too safety critical to skimp on
16v205
| posted on 13/11/18 at 11:25 AM |
I had a similar issue but to be fair OBP resolved it quickly so full marks for their after sales service.
I have the remote reservoirs mounted higher up than the pedal box using the flexi hose extensions, bought and fitted in April this year and they were
leaking by May.
Mine started to leak soon after having brake fluid in them, only a odd drip at first but got worse. Thought it was the flexis not sealing on the
threads etc but it wasn't.
My fault was the actual reservoirs were leaking between the white plastic body and the metal insert. There's a rubber washer inside the body
used to seal it up. They swapped out the reservoirs complete for me rather than try fix the faulty ones.
If your reservoirs are mounted on the master cylinder its worth taking a quick look as I dismissed the reservoirs straight off, I couldn't see
any fluid on them and the puddle was collecting at the master cylinder.
[Edited on 13/11/18 by 16v205]
16v205
| posted on 13/11/18 at 11:36 AM |
Forgot to add,
As bad as it sounds I used small bits of toilet tissue randomly wrapped around different parts of the brake system to see where the fluid would start
wicking up from. That's the way I found it but it took a few days, there was just no visible sign of a leak apart from a small puddle.
Rich
steve m
| posted on 13/11/18 at 07:38 PM |
Rich,
That is exactly the problem ive got, the leak originally was a drip, and possibly only one drip in weeks, but certainly required attention, only for
me to make the drip worse
Ive now got to the point were the reservoir and the adapter to master cylinder do not leak (hooray) and soon I will remove the master cylinder from
the car, reinstall the reservoir and check it all again
I feel im half way there to stop the leak, and if it does leak when fitted to the master cylinder, then that HAS to be the faulty item
