timsta
posted on 26/1/05 at 05:30 PM |
Toyota Engine Dimensions
Hiya,
Does anyone have the drawings/dimensions for the toyota 'S' Series engines, like the 3S-GTE or 3S-GE.
They were found in Celica's and MR2 Turbo's.
I can't find anything anywhere! Not even in the breakers yards at the mo.
Ta
Tim
Ian Pearson
posted on 26/1/05 at 05:40 PM |
I've a 3SGE that I plan to use once I've got through SVA..........
It's still in the car and I can get some rough dimensions if you like, but it won't be for a week or so as it's stored at my
parents.
ISTR reading somewhere that it is slightly taller & heavier than the pinto. It doesn't sit vertically in the engine bay so if space allows,
I shall mount it at the same angle & this should reduce the height.
timsta
posted on 26/1/05 at 06:49 PM |
Cheers for that Ian.
I'm not too concerned about the height as it is going in a middy, but I can't really start to design the rest without knowing the basic
size I will need for the engine bay.
Many Thanks, that would help no end!
Tim
r3nuf
posted on 26/1/05 at 11:52 PM |
Tim,
You could always give these boys a try.
http://www.japaneseengines.co.uk
Speak to either Phil or Shaun. Tell them i sent you!
Gary
Drive Fast....Brake Late....Take Chances
