belgian2b
posted on 22/5/21 at 08:11 PM |
3 parts wheels glued
Hello,
i started dissasembling some PLS 3 parts 13 inch to respray the centers and repolished the aluminium.
Bolts came out easily ( only one broke)
Problem, they have been glued
I can't even take the center part out.
What's the best solution ?
Warming ?
Apply force ?
they are quite old and the alloy is thin
Please help !
Gerardo
coyoteboy
posted on 22/5/21 at 08:54 PM |
Depends what they've been glued with. Heat (enough to degrade epoxy or silicone based glues) may affect your alloy temper.
Theshed
posted on 22/5/21 at 10:03 PM |
I would use heat. Most epoxies will let go at 200 degrees C or less. Most aluminium tempering is well over that. .... what could possibly go wrong....
coyoteboy
posted on 22/5/21 at 11:44 PM |
300C is the lowest annealing temp for Al alloys. You that sure of your heating....?
Sam_68
posted on 23/5/21 at 07:48 AM |
Are you sure it's glue?
Normal practice is to use a smear of silicone to seal between the sections (which is obviously sticks them together, too).
You might try carefully running an old-fashioned razor blade or a fine, sharp scalpel blade between the sections, to see if that separates them.
Edited to add:
If it is silicone sealant, obviously heat won't work... you'd end up with a puddle of molten alloy and a nice, if slightly fragile,
circular gasket of silicone left behind.
[Edited on 23/5/21 by Sam_68]
number-1
posted on 23/5/21 at 12:10 PM |
As above.
I had Gotti 3 piece 73a split rims and the only way to get the slicks on were to take the wheel apart. I used silicone to help seal each piece and
ensure they were air tight when re installing. They will part with a bit of effort and gentle prying .
belgian2b
posted on 23/5/21 at 08:14 PM |
Finally have them done.
WD40 all night + razor blade
Thanks for your help
Gerardo
