Stevestriker750
posted on 21/7/21 at 11:54 AM |
Crossflow starter motor upgrade
Has anyone upgraded to a faster spinning motor at all?
Mine turns over very slow at times although battery is good
Sam_68
posted on 21/7/21 at 12:28 PM |
Yeah, I fitted a geared starter motor to my old Crossflow Sylva (which used to be a pig to start, due to high compression and competition distributor
with no vacuum advance).
It worked well.
Stevestriker750
posted on 21/7/21 at 03:57 PM |
That's the same issue with mine. I think I do need a new battery also as it wouldn't start when fan was running from ignition.
Did you update battery too?
Any links for starter thst you fitted?
Many thanks
Sam_68
posted on 21/7/21 at 08:12 PM |
It's a while ago now, but I'm pretty sure it was an Edge starter motor, bought via Burtons.
I'd been down the route of changing battery changing/checking connections and earth cables before I resorted to it, but those had made little
difference - the standard starter just didn't have the guts to turn the engine over against the amount of static advance I was running.
The geared starter motor cured the problem on its own - simple as that.
Stevestriker750
posted on 21/7/21 at 09:33 PM |
Thank you Sam...
I'll have a look at what you've suggested and hopefully find one
Westy1994
posted on 22/7/21 at 12:29 AM |
You may chose to sort out the problem at source and fit a mapped dizzy instead, far cheaper than a starter, battery and whatever else may be needed.
Best single item I ever fitted.
[Edited on 22/7/21 by Westy1994]
http://stopjunkcalls.org.uk/forum
procomp
posted on 22/7/21 at 10:27 AM |
I supply these to a lot of the racers with lthe X FLOW or PINTO engines fitted. prices from £165. small light.
Ill try upload pics if interested.
Stevestriker750
posted on 22/7/21 at 10:37 AM |
Yes please mate
procomp
posted on 22/7/21 at 11:41 AM |
Hi i cant get a pic loaded up on here no matter what i try but the U2U is not responding either.
Give me a call / txt on 078 25 54 42 54 and i send a pic via phone.
Cheers Matt
Mr Whippy
posted on 23/7/21 at 02:25 PM |
Have you checked all the connections are good, and the cables are of sufficient gauge and to the minimum length? Does the engine have a good earth
lead and path back to the battery? These are all the things I'd check before paying out for a more powerful starter.
