bob
posted on 3/2/05 at 11:28 AM |
zetec flywheels
does anyone know if the 1.6 and 1.8 zetec flywheels are the same ?
I am planning to mate the type 9 to the zetec and have been advised to loose the 2 litre flywheel because of weight.
It seems most use the 1800 wheel but there are plenty 1600 zetecs kicking around in the scappies and when purchasing clutches they are marked up
1.6/1.8 so just a thought.
givemethebighammer
posted on 3/2/05 at 12:20 PM |
I used a 1.8 escort zetec flywheel (which I had lightend) and the 1.6 / 1.8 mondeo clutch. I can't imagine the 1.6 and 1.8 are too different.
If anything the 1.6 would be lighter ?. As long as you have the right clutch components and release bearing (CCT133 - capri) you should be OK.
might be wrong though
bob
posted on 3/2/05 at 12:27 PM |
Thanks wil
I thinks its best to just copy the others,i'll go for a 1800 flywheel and clutch with the same release bearing as yourself.
If its not broken dont fix it
[Edited on 3/2/05 by bob]
andyharding
posted on 3/2/05 at 12:29 PM |
quote: If anything the 1.6 would be lighter ?
I think it's more likely to be heavier as the engine has less torque and therefore it would be much easier to stall with a lighter flywheel.
Are you a Mac user or a retard?
bob
posted on 3/2/05 at 12:34 PM |
You could be right andy,i have a 1600 pinto flywheel in the garage and its heavier than the 2 litre one i fitted to pinto in the car now.
The only significant difference is that the clutch plate is far smaller on the 1.6 pinto flywheel so maybe zetecs are the same.
Anyhow it seems most people who instal the zetec use the 1800 flywheel,it was just a thought.
givemethebighammer
told you I could be wrong
so my theory that becuase the 1.8 flywheel is lighter than the 2.0, doesn't apply to the 1.6 then ?.
Mix
posted on 3/2/05 at 01:00 PM |
This was a bit of a minefield for me.
I have a 2.0l ex Mondeo Zetec to which I have fitted a 1.8l ex Mondeo flywheel. I originally ordered a clutch kit for a 1.8 Escort Zetec, (thinking
all zetecs were the same), but the spacing of the locating dowel holes were incompatable. A 1.8 Mondeo clutch fitted.
I have also heard that the 1.6 and 1.8 flywheels are the same providing they both come from the same vehicle model, however the Quinten Hazel
catalogue lists two different pressure plates so this may not be the case.
And just to complicate matters further I have been told that there are more than one type of 1.8l zetec flywheels fitted to Mondeos.
Mick
bob
posted on 3/2/05 at 01:22 PM |
Mick
Thanks for that info,it is a bit of a minefield with so many variations and matches on all the zetec instal websites.
One thing for sure everyone seems to use the same clutch release bearing.
Donners90
posted on 3/2/05 at 03:49 PM |
Looking at MicroCAT, the part numbers for the 1.6 and the 1.8 Zetec in Escort have the same part number 928M-6K390-AB so logic says they are the same.
The 1.6 and 1.8 in Mondeo have the same number as Escort, but the 2L in Mondeo has part number is 928M-6K390-CB
Hope this helps
James
bob
posted on 4/2/05 at 09:19 AM |
From reading the posts regarding the flywheels and clutch combos, i'm assuming that the 1800 flywheel i have just puchased that came from an
escort would be better fitted with the 1800 escort clutch ?
Mix
posted on 4/2/05 at 09:37 AM |
For the record the flywheel I removed from a 1.8l Mondeo had the part no. 928M 6398 AE
Mick
Lozec
posted on 4/2/05 at 10:15 AM |
Hello Bob,
I think you can't use the escort 1,8 clutch as it is, the splines won't match the type 9 gearbox. (talking from experience...)
The clutch you'll need is:
ECK 1410 /RS
Finis 5028341
//Lozec
[Edited on 4/2/05 by Lozec]
bob
posted on 4/2/05 at 12:56 PM |
lozek
Thanks very much for that info,much appreciated.
Have you a car model ID for that clutch ?
bob
posted on 8/2/05 at 11:28 AM |
Mick
Yep my 1.8 flywheel has come up the same number and came from an escort so there's no logic with Ford is there
Mix
posted on 8/2/05 at 12:26 PM |
You said it
I ended up taking the flywheel to the parts supplier and offering up pressure plates to ensure I got one that fitted.
Mick
bob
posted on 8/2/05 at 01:58 PM |
proof that this forum works perfectly if you ask the Question
Thanks again,at least i know for definate that the clutch i need is a 1.8 mondeo
I presume if two are listed i need the early one since this flywheel came from a 95 car.
Mix
posted on 8/2/05 at 04:34 PM |
Beware of the later ones, some are for hydraulic clutches.
Mick
verybudgetzetec
posted on 6/3/12 at 01:29 PM |
hi could anyone confirm if i have seen a flywheel in a scrappy, been told its a 1.8 one but i'm not 100% sure
the part number is the following
238 13 +GF+L 928V 6398 AF
let me know asap guys
much appraciated!
PSpirine
posted on 6/3/12 at 02:37 PM |
much appraciated!
928V is not a valid prefix - I'm assuming you're misreading 928M
The part is fitted as follows:
VL: NC MONDEO (C/DW27-C/DW162)
MD: - ______________________________
BS: -- ______________________________
VS: -- ______________________________
EN: EY ZETEC 1.8L DOHC EFI NA I4 G*MP
TR: RP 5 SPD MAN TRANS A EAO MTX75
And
EN: EM ZETEC 1.6L DOHC EFI NA I4 G*8
No other usages for this, but it has been up-revisioned to 928M 6398 AG which is also common with 1.6 and 1.8 Zetec Escorts (similarly the AE suffix
is common for 1.6 and 1.8 Zetecs in Mondeo, Fiesta and Escort)
[Edited on 6/3/12 by PSpirine]
verybudgetzetec
posted on 6/3/12 at 03:08 PM |
would you hazard a guess that what i'm looking at is a 1.8 flywheel? or a 2.0 one?
i cant get back to the scrappy until the weekend unfortuantely :O/
i should have took a weighing scales with me should'nt i
i believe the 2.0 is about 10kg & the 1.8 8kg but i could be wrong, its happened many times before LOL :OD
PSpirine
posted on 6/3/12 at 03:20 PM |
Also note:
928M-6398-AE/AF/AG
928M-6375-AE/AF/AG
928M-3K690-AB
Are hydraulic variants of flywheel (the 3 different lines reflect the 3 different levels of assembly, 3k690 being the top level complete flywheel
assembly)
Anything prior to that (alphabetical order in the suffix) will be non-hydraulic and presumably therefore not compatible?
PSpirine
posted on 6/3/12 at 03:21 PM |
If it's 928M 6398 AF it's definitely a 1.6/1.8 flywheel, not a 2.0
verybudgetzetec
posted on 6/3/12 at 03:33 PM |
that really appreciated that help! hopefully its the right flywheel for my rwd zetec application, i have my original 2.0 one of the mondeo doner car
so i'm hoping to locate a 1.8 zetec silvertop flywheel
