Author: Subject: Aligning input/output sprocket adapters
nick9one1
posted on 4/8/25 at 06:59 PM Reply With Quote
I need to precisely align these. The diff is mounted directly to the engine so the is no driveshaft or UJ.
When I finger tighten the bolts there is about 1/2mm of play. I can get it nicely aligned on the bench with a dial indicator, but it's not going to be easy when on the car.
I was thinking about drilling some 8mm holes and fitting some locating pegs. Glis this a good/bad idea? Other suggestions?
[Edited on 4/8/25 by nick9one1]
adithorp
posted on 5/8/25 at 06:49 AM Reply With Quote
Clocking the flanges on the outside diameter does rely on the outer being concentric with the center line, so you need to check that. I'd guess once you've clocked the flanges, drilling and fitting alignment dowels should ensure the fit.
The other issue you then have is perfect alignment of engine and diff. Even the slightest misalignment will put load on yhe input/output shaft bearings and cause premature failure.
I'd think using a rubber doughnut type coupling would be a better solution.
http://jpsc.org.uk/forum/
nick9one1
posted on 5/8/25 at 09:02 AM Reply With Quote
thank you. A guibo did cross my mind, but I really dont have a lot of space to play with.
I'll give the alignment dowls a go first. When I inevitably get a failed bearing I'll change the design
kj
posted on 5/8/25 at 08:21 PM Reply With Quote
Anyone got a sprocket adaptor for a kawasaki zx1200 or zx1400
Think about it, think about it again and then do it.
Dingz
posted on 5/8/25 at 10:38 PM Reply With Quote
Can you set them up in a lathe and machine a short spigot on one half and a recess for it to fit into in the other?
went on and on.
coyoteboy
posted on 6/8/25 at 08:34 AM Reply With Quote
I'd be making the engine and diff a single assembly that bolts out/in, nothing else is going to be reliable there.
nick9one1
posted on 6/8/25 at 08:45 AM Reply With Quote
You probably cant tell from the first picture I posted, but I've done this. I built a subframe that both rigidly mount to. The subframe then sits on rubber engine mounts.
(upside down)
[Edited on 6/8/25 by nick9one1]
posted on 6/8/25 at 03:52 PM Reply With Quote
What is the rear axle, diff and drive shafts from?
Are they all from the same donor car?
jacko
posted on 6/8/25 at 05:05 PM Reply With Quote
Looks like there is part of a VW beetle with toque. Suspension
555
adithorp
posted on 6/8/25 at 07:03 PM Reply With Quote
Usually both have a recess and the propshaft has spigots on its flanges.. You vould make a (stepped?) ring that fits in-between engaging both recess'.
Diff looks like Freelander maybe?
[Edited on 6/8/25 by adithorp]
posted on 7/8/25 at 08:16 AM Reply With Quote
It looks VW Beetle'ish to me, but I'm not really that familiar with the Beetle so not certain.
I guess it may be a mixture of donor parts choasen to achieve the desired layout.
coyoteboy
posted on 7/8/25 at 08:42 AM Reply With Quote
(upside down)
Ah in that case it should be fine if you do get it aligned properly. Sorry for the side-track.
