Author: Subject: Crank centreline
stevebubs
posted on 20/2/05 at 07:10 PM Reply With Quote
Crank centreline
Currently My engine is angled very slightly (approx 5 degrees) downwards towards the front of the car.
Is this going to cause me any problems, or should I look at bringing it back to horizontal?
Stephen
[Edited on 20/2/05 by stevebubs]
clbarclay
posted on 20/2/05 at 08:29 PM Reply With Quote
What engine is it, some engines work at quite a slop with the front end raised.
clbarclay
posted on 20/2/05 at 08:33 PM Reply With Quote
By the look of you photos its a zetec. Best is to mount at an angle close to that of donor car.
2 important points.
The first is that the sump oil feed most be fully submerg, to much angle and the oil could flow away from it.
The second is that the crankshaft does not want to be in contact with the oil. It can put strain on the crank and bearings it they get submerged.
[Edited on 20/2/05 by clbarclay]
stevebubs
posted on 20/2/05 at 08:35 PM Reply With Quote
Front end is *lower* than the back...
clbarclay
posted on 20/2/05 at 08:40 PM Reply With Quote
where about in the sump is the oil pump pick up. Front, middle or rear?
stevebubs
middle, and it's flat (chopped).
Think I'm going to put some plates under the mounts to raise it up to flat.
zetec
posted on 20/2/05 at 09:17 PM Reply With Quote
Mine is also down at the front and over to the left. Did it like this so I could use a Mondeo (large) oil filter. I've got a Dunnel sump which uses baffle plates. Mines been fine for the first 3500 miles of mixed use.
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
clbarclay
posted on 20/2/05 at 10:49 PM Reply With Quote
You could always try moving the oil pick up to the front to be on the safe side.
Mark Allanson
posted on 20/2/05 at 10:55 PM Reply With Quote
5° is not going to be an oil pickup problem, or you would get low oil pressure every time you went up/down a mild incline.
The only problem I can see is the prop. The input angle shoud equal the output angle, but I am not sure what the results of a mild missmatch would be
stevebubs
posted on 21/2/05 at 12:44 AM Reply With Quote
Aye - the prop is something that's worrying me a little - the top of the gearbox is getting rather close to the top of the tranny tunnel.(can't take pic at the moment as the car is full of cr#p I need to put away but can't because the car is in the way)
Can anyone shed any light? (Car is a live axle beast, btw)
Stephen
