Author: Subject: Blocking xe ex. cam
JJM
posted on 10/3/05 at 12:18 PM Reply With Quote
Blocking xe ex. cam
Any of you knowledgeable chaps know the size of the ball bearing thats used to block the oilway in the exhaust cam on an XE??
I know SBD use them just need a size so i can go local supplier.
Cheers!!
ned
posted on 10/3/05 at 12:26 PM Reply With Quote
don't know myself, might be worth asking on migweb.co.uk/forums though.
out of curiousity, why does it need replacing?
Ned.
beware, I've got yellow skin
JJM
posted on 10/3/05 at 12:33 PM Reply With Quote
Hi it doesnt need replacing it blocks the oilway as ive removed the dizzy.
I'll try Mig, cheers.
ned
posted on 10/3/05 at 12:51 PM Reply With Quote
let me know as I've got a distributorless kit with my throttle bodies, didn't realise this ballbearing was required, I have the blanking plate for where the dizzy was as it were..
Ned.
NS Dev
posted on 10/3/05 at 01:11 PM Reply With Quote
I used a cut down dizzy as a blanking plate, with a little ally plug turned up and pressed/loctited into the hole in the middle. I then just cut the dizzy shaft down sufficiently to fit inside this and left it blocking the end of the cam as it did originally. Looks quite neat but not as neat as cutting down the exhaust cam , blocking it and machining down the rear exhaust cam bearing housing, to get the engine all symmetrical, but then that's a lot of work just to make it look a bit nicer!!
JJM
posted on 10/3/05 at 03:08 PM Reply With Quote
Yeah thought about cutting the cam down,machining head etc but just not worth the hassle for me-i,d rather hammer in a ball bearing lol. Got the alloy blanking plate just need to find a bearing.Typical when you need a little thing like that and cant find one bah.
cidersurfer
posted on 10/3/05 at 08:44 PM Reply With Quote
FWIW QED supply the ball bearing with their dizzy block off plate
shimming solid lifters is a job for a friend...
Stu16v
posted on 10/3/05 at 09:17 PM Reply With Quote
I have still got the dizzy in mine - I just ripped the guts out, lopped off the rotor arm stub with a hacksaw, and used the three dizzy cap threads to hold a coil bracket. Proper locost...
