Author: Subject: Facet fuel pump
Dick Axtell
posted on 30/4/05 at 03:44 PM Reply With Quote
Facet fuel pump
Will the Facet fuel pump work when mounted vertically? Any reason not to mount it this way?
Dick
TTK77
posted on 30/4/05 at 05:15 PM Reply With Quote
Facet´s that we have used have worked in every position..
http://www.aar.fi
bigandy
posted on 30/4/05 at 06:55 PM Reply With Quote
I've mounted a facet solid state fuel pump (competition version) vertically, so it better had work! I can't see any reason why it shouldn't, providing it is lower than the average fuel level, it should be fine.
If it is significantly above the fuel level, then it might struggle priming itself.
Dammit! Too many decisions....
Dick Axtell
posted on 1/5/05 at 05:09 PM Reply With Quote
Thanks TTK77.
Chatted to Llama Motorsport at Stoneleigh today. Guy called David Round, very helpful, told me exactly how the interrupter type pump should be mounted.
(Vertically, with the "nut" end down, so the filter can be accessed).
Llama Motorsport - useful range of hose fittings and also good for brake hoses. See :- www.motorsport-plumbing.co.uk.
