Author: Subject: Help!!!!!! Won't start
rayward
posted on 1/7/05 at 04:48 PM Reply With Quote
Right engine specs
vulcan 1700 xFlow 135 bhp spec
Twin 40 dcoe carbs
Aldon Dizzy
Aldon Ignitor II (replaces points with magnetic pick up)
Flamethrower coil
Engine has always started and run fine before, drove off the drive other day, engine died and would not restart, when it did was firing through carbs (seemed to be cylinder 1 and 2) and out of exhaust, and ran rough then died again.
now won't start just fires out of exhaust.
have checked
petrol at carbs and in tank
changed dizzy cap+rotor arm
checked static timing
compression tested engine
charged battery
have spark at all four plugs
HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!
[Edited on 1/7/05 by rayward]
zilspeed
posted on 1/7/05 at 05:09 PM Reply With Quote
And you haven't messed about with plug leads ? Not 1342 firing order.
Sorry if I'm a mile off and you already know this.
Danozeman
posted on 1/7/05 at 05:22 PM Reply With Quote
Coil? Carb to manifold gaskets gone?
Dan
posted on 1/7/05 at 05:55 PM Reply With Quote
What sort of seal are you using at the carb to manifold connection? , the sort that use "o" rings can cause problems similar to yours if the seal gets blown out or sucked in , just a few minutes work to check?
rayward
posted on 4/7/05 at 10:59 AM Reply With Quote
got it running today, turned out to be the rotor arm, the spare i tried was duff aswell.
thanks for all your hel.
Ray
omega 24 v6
posted on 4/7/05 at 11:47 AM Reply With Quote
We had probs with the hot rod rotor arms on the 2ltr pinto ( Cost us 2 scottish opens:mad they burn out across the top contact apparantly theres a doobrie inside that does'nt like the high voltage coils that we were using (acording to the guy at the autosport show we should just use a std sierra coil).
rayward
posted on 4/7/05 at 12:56 PM Reply With Quote
sound about right, i've got a flame thrower coil, and the rotor arm has some sort of radio suppression gismo inside it, i'm gonna see if i can find one with the solid copper bit acroos the top that will fit.
Ray
