Humbug
posted on 13/7/05 at 07:46 AM |
Type 9 speedo drive - does it leak?
I am going to use an electronic speedo, but the speedo drive is currently open to the elements. Does anyone know if it actually goes right the way
through to the inside of the gearbox (i.e. is liable to seep oil out) or is it just a recess to take the square section speedo cable?
Just want to find out if I need to block it up with something - I would rather find out now!
mookaloid
posted on 13/7/05 at 07:48 AM |
Block it up!
indykid
posted on 13/7/05 at 07:52 AM |
cut the end off the old speedo cable (the steel bell shaped bit, and fill the end with gripfill/sikaflex/silicone, and then use the circlip to hold it
in.
made to measure solution
tom
Humbug
posted on 13/7/05 at 11:04 AM |
Thanks all. I don't have a speedo cable, but I will make sure the hole is blocked up
johnjulie
posted on 13/7/05 at 07:53 PM |
No need to block it off, if you have the square holed plastic bit still there, the hole doesn't go right through!
Cheers J&J
