Robster
posted on 15/7/05 at 09:10 AM |
Clutch cable query (I know it's been asked before...)
Sorry, guys, I know this has been asked before & I have been searching through old posts for the answer but just can't find what I am
looking for!
I have a 1300XFlow engine with a Type9 gearbox and Stuart Taylor floor mounted pedals. Which clutch cable is the best to use? Presumably a standard
sierra item?
Also, I'm assuming the best route for the cable is the same as with the Luego floor mounted box - through the chassis rail. Does the sierra
cable come with the fittings suggested in the Luego manual?
Thx for your help!
Rob.
James
posted on 15/7/05 at 09:27 AM |
The standard Sierra item isn't adjustable.
The 3.0 Capri is though. This is what I've used with my Type9 and floor mounted pedals. Was about £1.50 from an auto show.
HTH,
James
- Muhammad Ali
Markp
posted on 15/7/05 at 07:17 PM |
I agree with James,
I used the mk2 escort clutch cable first and it was too short, it made the cable snap as it was too tight to go from the pedals, out the chassis and
to the box. the capri cable is a better length.
Mark
Robster
posted on 16/7/05 at 04:26 PM |
Okay, thx for the responses guys. I have found my donor Escort cable and thought that might do but it is a very tight angle. Looks like I'll be
off to my local motor factor next week for a Capri item.
Cheers!
Rob.
theconrodkid
posted on 16/7/05 at 04:45 PM |
mine is capri,dont know what model as there are plenty of them,qcc1010 is the qh number
who cares who wins
pass the pork pies
MikeRJ
posted on 16/7/05 at 07:17 PM |
http://www2.qha.com/catalogues/QH09ClutchCablesRHD.pdf lists the QCC1010 as being from a 1.6 P100 (Sierra pickup), and thre Moprod catalogue shows it
was also used on the 1.6 & 2.0 MkIII Cortina, and the early 1.6 & 2.0 Mk IV Cortina. No mention of that part number under Capris though.
theconrodkid
posted on 16/7/05 at 09:17 PM |
weird,it says 1010 on the lable and is too short for a tina,afaik seirra based p100,s were self adjusting
who cares who wins
pass the pork pies
