ethomas
posted on 18/7/05 at 11:45 AM |
Engone Backplate
I have an XR4i engine and gearbox but I am missing the backplate which goes between them. Is this essential or is it a nice to have item.
I have found it extremely hard to get hold of one, and I would prefer not spending the day in a scrappy removing engine and flywheel to get one, but I
will bite the bullet if it is needed.
Ed
DaveFJ
posted on 18/7/05 at 12:04 PM |
easily made from a thin sheet of steel or ally (although ally may crack with fatigue)
Dave
stevebubs
posted on 18/7/05 at 12:05 PM |
Just cut an ali spacer out...less hassle then spending a day in a scrappie
ethomas
posted on 18/7/05 at 12:33 PM |
Cheers for that, should I just draw around the bellhousing and then drill out the bolt holes?
big_wasa
posted on 18/7/05 at 07:02 PM |
Yep I could not be bothered to strip a car for one so I made one aswell...
posted on 18/7/05 at 07:48 PM |
The one on the car has a split in it so you can thread it on without removing the flywheel to make the job easier.
