Author: Subject: Mounting Pinto- still! Part Deux
James
posted on 14/1/03 at 05:16 PM Reply With Quote
Nearly finished my engine mounts but just been wondering at what angle should the Pinto sit? By which I mean in a longitudinal direction should the top of the block be horizontal?
I would have put it horizontal but seem to remember a post where someone said a Crossflow should tilt up at the front and therefore wondered if Pinto was possibly similar in this regard.
Just thought I'd check!
Thanks,
James
interestedparty
posted on 14/1/03 at 05:42 PM Reply With Quote
Is it on carburettor/s? Have a look at the float chamber and manifold, some of these are canted to allow for sloping back fitment in the original car. Can't see that it matters though, I'd fit it wherever gets the best clearance, bonnet height etc
John
As some day it may happen that a victim must be found,
I've got a little list-- I've got a little list
Of society offenders who might well be underground,
And who never would be missed-- who never would be missed!
James
posted on 14/1/03 at 06:43 PM Reply With Quote
John
Hi John,
It's the injection '205' model but I'm planning to fit carbs.
James
jollygreengiant
posted on 14/1/03 at 07:15 PM Reply With Quote
James.
I kid you not, if you are going to fit Carbs then you WILL have to change the head. The inlet ports on an injection head are pear shaped to allow for the injectors.
All carb manifolds WILL all have round ports and you WILL end up with air leaks.
Another of the governing factors that will affect the fitting of the engine is which rear suspension you are using. If you are using IRS then generally you can mount on a level plane because there is no movement of the Diff. If using a live axle then a shallow angle is better because they were orignally designed to have a slight upward angle starting from the diff. this was to give better oil flow around the diff and amongst other things it helped to control axle tramping.
Enjoy
James
posted on 15/1/03 at 10:14 AM Reply With Quote
Originally posted by jollygreengiant
James.
Oh Crap
Are there no compatible manifolds available? That's a real pity, I'd gathered the '205' head was superior (in a gas flowing sense) to the standard.
In fact what's more of a pity is I've already rebuilt the '205' one!
Could I get one made up possibly?
What about a cut and shut between a carb and an injection manifold? Ie. weld the bottom part of an injection with the top half of a carb? Possible??
I know some people have chopped the injection (to get it to fit) so presumably the above is theoretically possible?
Thanks,
James
[Edited on 15/1/03 by James]
philgregson
posted on 15/1/03 at 10:45 AM Reply With Quote
Not wanting to disagree with the Jolly GG 'cos he obviously knows considerably more about this sort of thing than I do - But!
I have a sierra 2.0 pinto with EFI (got it for free for bits but it has accidently ended up on the road for her indoors - bugger) that I was thinking of using the engine from at one point.
I was discussing the excessive injection height with the car chap round the corner who (bear with me here - I'll get to the point eventually), amongst other things, restores scimitars. He buys old V6 sierras and granadas, sticks the V6's in the Scimitars, sticks pintos in the original car and sells them on. Anyway he says that he 'just sticks carbs on the EFI ones' and they apparently run well without any head swapping.
Now I don't know if I've misunderstood somewhere along the line or if we are talking about a diferent engine here but I thought it was worth mentioning.
Phil.
jollygreengiant
posted on 15/1/03 at 11:06 AM Reply With Quote
Ok so he sells them on. is he going to drive them & pay for the repair bills down the road when all goes (sorry) pear shapped. Nope muggins who bought the car will.
Motor trade in a nut shell. (IMHO)
Do the job right first time & it won't come back.
Or James how about an alley spacer/adapter plate. Could be good, it would deffinately give you a good swirl effect over the backs of the valves.?
Enjoy.
bob
posted on 15/1/03 at 04:15 PM Reply With Quote
JAMES & JJG
I got a feeling you can buy those adapter plates for the manifold,its either Vulcan/Burtons/dunnels or maybe Webers.
James
posted on 16/1/03 at 10:46 AM Reply With Quote
Phoned Vulcan
Well, I've spoken to Steve at Vulcan about it, really nice, helpful guy. Seems there's a couple of options available.
Apparently you can have the inlet holes welded partially (to make them circular) or you can buy a special manifold (that's 1" long apparently!) that's designed for it. It's £87+vat!
Apparently you need 9" space between the end of the engine and the side rails.
Decisions decisions...
James
[Edited on 16/1/03 by James]
James
posted on 16/1/03 at 10:58 AM Reply With Quote
Interestingly he also told me that 45s were more economical than 40s which surprised me. He said this was because for a given fuel output the 40s had to be working much harder than 45s (or atleast I think that was the reason atleast ).
James
jollygreengiant
posted on 16/1/03 at 03:07 PM Reply With Quote
The number (ie 40/45/48) refers to the maximum diameter of the carb before you fit venturi's. If a 1.6 Kent lump runs sweet on 40's (possibly 45's if your racing) then think about the extra air flow though the carb that a 2.0 will require. This Will create extra vacuum through the main idle jets therefore increasing fuel flow. Go up to 45/48 for a 2.0 lump and the economy returns because you don't have the same problem with balancing air-flow/fuel.
Enjoy.
James
posted on 21/1/03 at 12:31 PM Reply With Quote
Ok, well here's a picture of Vulcan's adapter:
http://www.locostbuilders.co.uk/xmb/photos/cgi-bin/showpic.pl?adapter.jpg
to fit carbs to the '205' head. It's £87+vat
Opinions anybody?
James
[Edited on 21/1/03 by James]
interestedparty
posted on 21/1/03 at 01:09 PM Reply With Quote
Originally posted by James
Opinions anybody?
Link doesn't work, James, so no opinions
John
James
posted on 21/1/03 at 01:57 PM Reply With Quote
Opinions anybody?
John
Right! Three edit's later and it no longer put's a space in the middle of the link! Apologies to all those for whom it didn't work!
Cheers, James
jollygreengiant
posted on 21/1/03 at 02:21 PM Reply With Quote
should do the job. looks pretty good. Be even better with '45s' on it.
You just need the gaskets now. You will need to give ford a ring to get the injection manifold gasket though. all the others will be off the shelf from a factor. See its not all doom & gloom.
Enjoy.
Better Yet some really sexy 48's or 50's
[Edited on 21/1/03 by jollygreengiant]
interestedparty
posted on 21/1/03 at 02:36 PM Reply With Quote
Opinions anybody?
Yeah, go on, you know you want it, don't you
John
James
posted on 21/1/03 at 05:48 PM Reply With Quote
Opinions anybody?
John
Well, I'm not sure what to do now.
The Pumaracing Pinto guide is pretty interesting:
http://www.pumaracing.co.uk/pinto.htm
I think that was where I first read about the 205 head being better (10 BHP!) but on re-reading I've noticed that once you've got either head gas-flowed the result is the same.
So, the question is, is 10BHP worth an £87+vat adapter?
James
James
posted on 21/1/03 at 05:58 PM Reply With Quote
Alright James, stop being a t055er
Alright, alright, as someone's probably about to point out to me- I'm going to need to buy a manifold anyway so if I offset the manifold cost (approx £50?) against the £87 it works out so cheap it's practically free!
Very Locost...
James
jollygreengiant
posted on 21/1/03 at 07:53 PM Reply With Quote
James look at it this way and it will seem well cheap.
F1 teams spend millions trying to get a 10bhp power inrease.
Or
original bhp 100. new bhp 110 = 10% increase. PLUS I get the lovely sound of those CARBS. YES there is a god.
OR
The price of a smile can have no value.
Enjoy.
