Author: Subject: vacuum on dizzy
scutter
posted on 21/2/03 at 05:07 PM Reply With Quote
vacuum on dizzy
Gents, just about to fit the dizzy to the engine(X-flow, twin40s) and was wondering what or where to fit the vacuum hose to. The dizzy is an electronic one out of the valencia engine.
As always any advice welcomed. Dan.
jollygreengiant
posted on 21/2/03 at 11:28 PM Reply With Quote
Can't fit a vaccuum take off to any cylinders if running twin 40's cos if you go into just 1 cylider you get such an erratic vaccuum pulse that the vaccuum unit goes tits up very quickly (gets vibrated to death & takes a matter of days) & if you tap into multiple barrels then you effectively create an air leak across the manifold and get incorrect fueling. So just fit the dizzy & forget about the vaccuum advance.
Enjoy.
kingr
posted on 23/2/03 at 02:23 PM Reply With Quote
Doesn't that mess up your ignition timing?
Kingr
locodude
posted on 23/2/03 at 07:38 PM Reply With Quote
Check out Dave Andrews site for tips on how to modify distributors or bite the bullet and buy a modified one from Aldon or Vulcan. I supplied engine specs and a dizzy (Lucas type) to Aldon and they remapped it and de-vacuumed it for about £65.
scutter
posted on 23/2/03 at 09:11 PM Reply With Quote
Cheers All, will contact aldon in the morning.
Dan
