Author: Subject: xflow alloy rocket cover
posted on 4/1/06 at 11:08 AM Reply With Quote
the xflow cork gasket has locating tags but the alloy rocker cover I have and others I have seen have a flat base without these location gaps. Is that going to cause a problem?
Deckman001
posted on 4/1/06 at 11:21 AM Reply With Quote
Nope, as long as the gasket still seals the cover
Jason
David Jenkins
posted on 4/1/06 at 11:54 AM Reply With Quote
Some alloy covers don't use the cork gasket, because the mating surface is flatter than the old tin cover. These can use conventional gasket material.
Might be worth asking your supplier...
