Author: Subject: sump thickness
liam.mccaffrey
posted on 1/8/06 at 06:53 AM Reply With Quote
sump thickness
is 0.9mm sheet too thin for a fabricated sump?
Cheers Liam Mc
Build Blog
Build Photo Album
MikeRJ
posted on 1/8/06 at 07:40 AM Reply With Quote
I would say it a bit on the thin side. It's only going to take a small stone hitting it to cause a lot of damage.
16 gauge would be more suitable and is easy to get hold of.
David Jenkins
posted on 1/8/06 at 07:43 AM Reply With Quote
Mind you, if you've ever tried modifying a pressed-steel sump, you'll find that the metal at the corners of the base is VERY thin - less than 0.5mm! Makes welding a real pain, unless you take steps to avoid the problem.
liam.mccaffrey
posted on 1/8/06 at 07:46 AM Reply With Quote
i could use a sump guard also?
assuming i use 16 gauge for the sump any ideas what i could use my 2 8x4 sheets of 0.9mm for
Build Blog
Build Photo Album
cossey
Contributor
Posts 430
Registered 5/12/05
Location Kent
Member Is Offline
Photo Archive Go!
Building: a pile of bits that will someday be a fisher fury
posted on 1/8/06 at 09:15 AM Reply With Quote
pannelling under the engine bay
NS Dev
posted on 1/8/06 at 11:44 AM Reply With Quote
fuel tank, plus any panelling not being done in ally (would suggest parts like tunnel sides, passenger footwell and front section under radiator would all benefit from the strength of steel stitch welded in if you have it going spare.
it's ony about £30 worth for the two sheets though so not too serious a problem!
