macspeedy
posted on 17/6/03 at 07:45 PM |
throttle linkage kits
Trying to save money, has anyone tried to make there own throttle linkages? have twin 45 webers on pinto.
ned
posted on 19/6/03 at 08:53 AM |
i've seen this done, very easy.
get a piece of steel and bend it in the shape of a top hat, holes in the base should attach to the mounting holes in the carbs, then drill a hole for
the cable and make a support for the cable sleeve so th cable doesn't fray. get one of those cable clamps and slot it into an arm from the
linkage shaft and bob's your uncle.
I have seen one put together in about half an hour.
If no one understand i may draw a diagram....
Ned.
beware, I've got yellow skin
