Author: Subject: today's bit of fun - name the gasket
posted on 30/3/07 at 09:55 AM Reply With Quote
which bits are the gaskets for?
have I got this right?
top & bottom row = sump
left/rightmost = crank seals
3 square ones = fuel pump (why 3?)
what are the two 'n' shaped ones on left?
'n' shape with round bit = timing cover?
inside the is the oil pump gasket.
is there a separate gasket for the water pump? or is it part of timing cover?
reason for asking is will this together with a tipo end gsket be all I need gasket wise?
nitram38
posted on 30/3/07 at 10:27 AM Reply With Quote
Ford x-flow?
donut
posted on 30/3/07 at 10:43 AM Reply With Quote
Merlin V12 aero engine as fitted to Spitfires, Mustangs, Mosquito's and Lancasters?
Am i anywhere near?
russbost
posted on 30/3/07 at 10:58 AM Reply With Quote
Looks like Kent to me too. There are 3 fuel pump gaskets cos you probably have an insulator & one goes each side of that, the third is probably a different thickness for different units. Surely the "N" shaped on the left are timing cover, tho' no idea why 2, & "N" shaped on right waterpump, I certainly don't recall the w/pump & t/cover being on the same gasket, tho it's about 15 years since I was familiar with the Kent - You have all the sump/crank/oil pump ones correct. Re what gaskets you need - depwnds what you're doing!! HLH
Danozeman
posted on 30/3/07 at 11:02 AM Reply With Quote
Starting from left top.
Fred
George
Bob
Jim
Sorry ill get my coat. Im trying to ease a boring horrible friday,.
Are they crossflow??
Dan
Mr Whippy
posted on 30/3/07 at 11:03 AM Reply With Quote
pah that's what I was going to do
MikeRJ
posted on 30/3/07 at 11:22 AM Reply With Quote
When you buy a gasket kit like this for the xflow, the waterpump gasket is part of the timing cover gasket (the round bit on the n shaped gasket). If you buy a waterpump it comes with a separate gasket, so if replacing the water pump at a later date you have to cut the old one away from the timing gasket when you remove the old pump.
The two n shaped gaskets on the left are for the crank oil seal carrier that fits at the flywheel end of the crank. I suspect that earlier engines may have a different design, thus the two slightly different gaskets.
Don't know why you have a spare fuel pump gasket, I only got two in my Payen set.
steve m
posted on 30/3/07 at 11:33 AM Reply With Quote
there isnt "a spare fuel pump gasket"
the black plastic spacer is sandwiched between two gaskets
Marlon
posted on 30/3/07 at 11:42 AM Reply With Quote
It looks very much like this one to me
which is said to be for an early cortina 1967 to 1970 I'm not sure what engine is fitted to it though.
john
Band Anyone?
Linky to SWMBO 's band
Linky to Brother in laws band
MKoc 1081
MikeRJ
posted on 30/3/07 at 12:18 PM Reply With Quote
Ahh, orginal post just said three gaskets. I've never had a new spacer supplied in a gasket set before!
posted on 30/3/07 at 01:06 PM Reply With Quote
yes it is crossflow - seems it is all there - interesting about the waterpump being a separate item and the fule pump spacer thingy.
thanks for info.
