Ham
| posted on 4/4/07 at 11:12 AM |
X Flow vibration
Hi All,
I am getting frustrated by a vibration/resonance from the X Flow.It started slowly and has gotten progressively worse.It occurs at 4000 rpm and
dissapears at around 5200 rpm.It sounds like a metalic plate rattling? I noticed that the spacer plate between the engine and gearbox was loose, I
tightened that but the noise remained. The sound comes from the right hand side (carb side) - Any ideas......
I have found that one of the shafts on my carb has some play?, could it be distrubutor weights(I had the curve modified)
The engine is running really well so I dont see it as anything major. but it does make a lot of noise.
Marcus
| posted on 4/4/07 at 12:00 PM |
Sounds similar to mine - was the valve in the oil separator rattling, soon to be replaced with catch tank.
Marcus
Because kits are for girls!!
Ham
| posted on 4/4/07 at 01:04 PM |
Hi Marcus, can the valve make that much noise, I can hear this vibration over the engine and exhaust?
mookaloid
| posted on 4/4/07 at 01:40 PM |
It's not your clutch release bearing is it?
They can chatter a bit...although usually at idle.
Mark
Ham
| posted on 4/4/07 at 02:25 PM |
Hi Mark,
Nope not clutch or bearing, the noise does not change with the clutch in our out, definately from the side near the carb
MikeRJ
| posted on 4/4/07 at 04:02 PM |
Trying probing around on the engine with a long screwdriver with the handle pressed up to your ear (watching out for fan belts!). This should narrow
down the source pretty quickly.
Ham
| posted on 12/4/07 at 06:56 AM |
Quick update on the vibration problem;
I got hold of a mechanics stethoscope and had a good listen, the noise seemed to come from the carb, I swapped the carb and the noise remained? I then
thought that it was an engine vibration causing the noise and looked for that.My first thought was loose flywheel and set about removing the starter
and spacer plate to have a look, the engine was still hot and after loosing skin to the manifold I called it quits and re tightened the starter (pre
engaged type).Last night started her up and the noise has gone!!! it seems the starter may have been slightly loose, the vibration could have been
caused by either the spacer plate between the starter and bell hosing or the actual starter vibrating.
Strange thing is that the noise was definately loudest at the carb, I presume that this is due to the barrel of the carb "amplifying" the
noise?
