Author: Subject: red top v zetec
robbydee
posted on 9/5/07 at 08:48 PM Reply With Quote
red top v zetec
Current pinto runner,
looking to start collecting parts,
Which is the better option?
Zetec or Redtop?
I know what is required for fitting a zetec, can any one give help on the redtop,
i have found a unit from a gsi and a gte.
thanks ROb..
stevebubs
posted on 9/5/07 at 09:07 PM Reply With Quote
you'll need different varieties of the same things for both but a new bellhousing will be required on top if going down the redtop route.
[Edited on 9/5/07 by stevebubs]
DIY Si
posted on 9/5/07 at 10:31 PM Reply With Quote
The red top out does the Zetec all week long. It may be a bit harder to fit (new bell housing etc), but will be worth the extra trouble.
Sun Tzu, The Art of War
robbydee
posted on 9/5/07 at 10:42 PM Reply With Quote
currently my pinto is fitted with megajolt and r1 bike carbs,
is there any crank sensor on a xe ?
robbydee
posted on 9/5/07 at 10:44 PM Reply With Quote
any receomendations for
sump
bellhousing
clutch
release bearing
starter
alternator
thanks currently searching the archives......
stevebubs
posted on 9/5/07 at 10:57 PM Reply With Quote
SBD would be a one stop shop...
procomp
posted on 10/5/07 at 07:02 AM Reply With Quote
Hi wheres nsdev. I dont belive that the letters VX have been mentioned whithout him knowing.
I would try and argue a case for the blue oval but think it would be pointless due to the fact that except for the adiitional bell housing £ for £ it wont beat th VX.
Even if it is heavier .
cheers matt
iank
posted on 10/5/07 at 09:22 AM Reply With Quote
As above
Zetec cheaper if you want around 150bhp
XE cheaper if you want around 200bhp
Last guestimate I saw was the XE is 10-15kg heaver so not enough to worry about.
For alternator the nippon denso one from the daihatsu charade (and some others) is the normal favourite.
[Edited on 10/5/07 by iank]
Anonymous
zetec
posted on 10/5/07 at 10:18 AM Reply With Quote
I've no doubt the VX is a better standard engine for power, the problem I had was finding one in good nick that didn't need a rebuild. When you see how cheap you can pick up zetecs for that don't need any money spent on a rebuild things change a a bit.
You can spend the money normally spent rebuilding the VX on cams/head for the zetec and end up with 190-200bhp so things arn't always what they seem...just a thought.
Or just fit a Duratec and get the best of both worlds.
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
