Author: Subject: bike engine ( reverse gear )
markf
posted on 27/5/07 at 10:03 PM Reply With Quote
here's one for you lot,,,
today at work, whilst standing on the landing of the prison where i work, ( im a screw not a con ), i suddenley had an idea for a bike engined car, to solve the problem of reverse gear, but i have no idea if it is stupid or not, my question is can an MT75 gear box be used, for the reverse gear, an if so, what gear would be used for forward gears with the bike engine, now some one tell me, is it a stupid idea ?
cheers
mark
ReMan
posted on 27/5/07 at 10:07 PM Reply With Quote
Not stupid, it has been discussed before
http://www.locostbuilders.co.uk/viewthread.php?tid=51791
It has its advantages, but the weight tends to negate them somewhat
adithorp
posted on 27/5/07 at 10:08 PM Reply With Quote
30 forward gears and 6 reverse! Yep thats a stupid idea.
Adrian
stevec
posted on 27/5/07 at 10:11 PM Reply With Quote
Adrian
Dont beat about the bush, get to the point man.
Fatgadget
posted on 27/5/07 at 10:14 PM Reply With Quote
Surely there must be a way of removing the forward gears and just retaining the reverse?
zilspeed
posted on 27/5/07 at 10:19 PM Reply With Quote
One of Ned's mates used a 4 speed escort box in the tunnel 'backwards.
That allows the reverse gear and if put into an intermediate gear it gears the car up for cruising.
Still goes like the wind apparently.
ReMan
posted on 27/5/07 at 10:21 PM Reply With Quote
Then you just need to remove the 20Kg of gearbox casing and bingo
smart51
posted on 28/5/07 at 08:25 AM Reply With Quote
4th gear in ford boxes is usually 1:1, so ideal for going forwards. You can then use 5th as an overdrive for cruising. Even if you took the other gears out, it would still be heavier than a reverse box and if you had to have all the coupings made to join the bike's sprocket output with the gearbox input, it might not be much cheaper.
adithorp
posted on 28/5/07 at 10:14 AM Reply With Quote
So with 6 reverse gears; None of us would be stupid enough to try them all...would we?
Adrian
Hammerhead
posted on 28/5/07 at 11:23 AM Reply With Quote
hasn't the dp1 or the v8 bec atom dennis is working on got a mt75 box? dpcars.com
ChrisGamlin
posted on 28/5/07 at 02:30 PM Reply With Quote
The V8 may do but then it doesn't have an integrated gearbox like a normal bike engine, so it needs a gearbox anyway.
As other have said the main disadvantages are weight, packaging and additional transmissions losses, hence why not many people have bothered doing it.
chunkytfg
posted on 28/5/07 at 07:27 PM Reply With Quote
Adrian
Nah course we wouldnt.
14 sec 1/4's backwards
adithorp
posted on 28/5/07 at 08:01 PM Reply With Quote
Does anyone remember the Austin Champ? Built for the army, RollsRoyce engine and 6 gears..forward and reverse. Plenty of national servicemen got in trouble for testing the reverse and fliping them.
Adrian
