Author: Subject: Kalimex - K-Seal coolant leak repair
Snuggs
posted on 5/6/07 at 07:28 PM Reply With Quote
Anyone used this stuff?
Is it any good?
http://www.fasteronline.co.uk/Kalimex-kseal-coolant-leak-repair-p-3043.html
http://www.topcashback.co.uk/ref/snuggstcb
Spider pig, spider pig, does whatever a spider pig does.
I doubt therefore I may be.
Luposlipophobia : Fear of being chased by wolves around a freshly waxed kitchen floor, while wearing only socks on your feet.
My mind not only wanders, sometimes it leaves completely!
http://www.venganza.org
http://www.jesusandmo.net/
http://www.snuggs.co.uk
posted on 5/6/07 at 08:47 PM Reply With Quote
Not sure but IIRC that could be the stuff recommended by British trident
Guinness
posted on 5/6/07 at 08:51 PM Reply With Quote
Yup that was the stuff recommended by British Trident.
I had a couple of water leaks on the BMW, one from the water pump and one from the radiator. Stuck a can of that in it and it cured the leak from the radiator like magic.
However the leak on the water pump turned out to be through the bearing, rather than the gasket so it didn't work on that!
Have replaced the pump now though.
Mike
posted on 5/6/07 at 08:54 PM Reply With Quote
Not the Viento?
Snuggs
posted on 5/6/07 at 09:12 PM Reply With Quote
Not the Viento?
Nope. The Jag
