cm
| posted on 9/6/07 at 10:12 AM |
Rover on Carbs
Hi All,
I have just took the plunge and taken my locost of the road and removed the engine (As you do). Right now I am planning on fitting a rover k series
lump but am waying up my options.
I already have the following:
Rover 214 full car good engine
Caterham Manifold
Caterham Low Lying Sump
Alloy bellhousing for Type 9 (Need type 9 tho)
Can get some mounts made.
Now what do I do,
Fit the rover engine with everything from the doner or:
Fit the rover on carb's (How would I go about this)
The engine I tool out was a 1300cc xflow so what would be required in getting it running.
Any help apriciated, or if someone wanted to lend a hand that would be great.
Ian
Hammerhead
| posted on 9/6/07 at 10:39 AM |
You may need the type 9 gearbox from a V6 2.8 ford (capri or sierra) as it has a longer input shaft for the caterham bellhousing.
You may also need the crank drilling for a caterham spigot bearing. The 1.4 and 1.6 usually need the mod, The 1.8 has a larger hole. Do a search on
blatchat to get more details.
Also search humbugs posts on here as he has a 1.4 k in his car.
[Edited on 9/6/07 by Hammerhead]
