Author: Subject: Westfield Type 9 Gearbox Mount - Fitting
andyace
posted on 13/6/07 at 08:27 AM Reply With Quote
I have just received my westfield type 9 gearbox mount and am now wondering how to fit it. It is not wide enough to span the transmission tunnel.
I was thinking of using the middle bit of the sierra mount which is just the right size, however has the rubber mount in the middle.
Has anyone used this before, it looks like I could cut out the rubber centre section and bolt in the new westfield mount.
I will try and get some pics later.
Many thanks, Andy
stuart_g
posted on 13/6/07 at 08:32 AM Reply With Quote
why don't you make an adapter plate to span the area where the mount fixes, then bolt the mount to the adapter plate.
andyace
posted on 13/6/07 at 08:36 AM Reply With Quote
Thats Plan B, sounds a little bit more work that adapting the sierra bit. I guess my answer really is to try it and see.
TGR-ECOSSE
posted on 13/6/07 at 10:48 AM Reply With Quote
There is a picture of one in this thread Linky that Mark Allanson posted.
Ronnie
James
posted on 13/6/07 at 10:52 AM Reply With Quote
I welded on a couple of plates of 3mm strip to the chassis. Put an 8mm or so hole in each and bolted the mount to that.
HTH,
James
andyace
posted on 13/6/07 at 10:55 AM Reply With Quote
Ronnie
Lovely thanks, I should use the search more really.
