Author: Subject: Are bellhousings the same for xflow and sierra engines?
theohighland
posted on 13/6/07 at 12:46 PM Reply With Quote
Hi, I am in need of a bellhousing to go between my type 9 and xflow, but realise i am more likely to find one off a type 9 in a sierra.
So my question is will this fit a xflow?
Theo
andylancaster3000
posted on 13/6/07 at 12:53 PM Reply With Quote
Yes it will fit. Most 4 cylinder ford blocks are the same bolt pattern. Exceptions are the newer duratecs and zetec se blocks.
theohighland
posted on 13/6/07 at 01:14 PM Reply With Quote
excellent, thanks very much.
my next question then is which sierra's used a type 9, rather han the MT75?
Cheers again,
Theo
vinny1275
posted on 13/6/07 at 01:33 PM Reply With Quote
Cheers again,
Theo
IIRC, they changed at about 1988 / 1989. Also IIRC, the MT75 bellhousing is part of the gearbox, and not removeable. I've seen quite a few on Ebay over the past few months, so should be easy to get hold of...
HTH
Vince
theohighland
posted on 13/6/07 at 01:41 PM Reply With Quote
yeah i have a dohc with MT75 already and the bellhousings is a part of the casing and non removeable, but i have a book chassis so am now going to use a xflow and type9, which i have, just need the bellhousing now to put them together
will give my local breakers a call
Memphis Twin
posted on 13/6/07 at 02:34 PM Reply With Quote
Mt75 is a much stronger box than the Type 9 ...if you can get it to fit, I'd use that.
speedyxjs
posted on 13/6/07 at 03:10 PM Reply With Quote
I believe the MT75 is wider than a Type 9 though.
zilspeed
posted on 13/6/07 at 03:59 PM Reply With Quote
There are also type 9s out there with an integral pig iron bell housing.
I'm not suggesting for a second that you would want one, but they do exist.
posted on 13/6/07 at 04:43 PM Reply With Quote
Got a cast iron bell housing you can have if you get stuck although postage may be a bit high
stevebubs
posted on 13/6/07 at 06:46 PM Reply With Quote
Cheers again,
Theo
Ones with Reverse located in the top left.
MikeRJ
posted on 14/6/07 at 02:04 PM Reply With Quote
Try to get hold of an RS2000 bellhousing (or buy new from Rally Design). The weight saving over the cast iron lump is very significant.
