Author: Subject: blackbird thorttle bodies
oadamo
posted on 2/7/07 at 06:28 PM Reply With Quote
blackbird thorttle bodies are these any good. anyone got them. are the injectors ok on a 2l zetec ive just bought some for £15
adam
[Edited on 2/7/07 by oadamo]
oadamo
posted on 2/7/07 at 08:35 PM Reply With Quote
its taken me an hour but ive found the specs
Make/Model: CBR 1100 Blackbird
Year: ??
Number of Tb: 2
Inside Diameter: 42mm
Center-Center (left to right from behind): 85-85-85mm
Overall Length:
Outside Diameter (intake):
Outside Diameter (filter):
Separate casting: No (dual Tb´s)
Injector Make/Model: Keihin
Flow Rate (43psi/100%): ~335cc/min, 13Ω
Fuel Rail Inside Diameter:
Additional Info:
adam
andrew-theasby
posted on 2/7/07 at 10:38 PM Reply With Quote
Ive just got some too for my 2.0 vx engine. Not tried them, but they seem to be most common ones for the vauxhall conversion so should be ok on zetec too. They dont look too easy to space if you want perfect allignment, but they are probably some of the widest spaced t/b's any way, so i think there about 5mm off on my engine so wont bother spacing them. I picked up an engine loom on ebay for about a fiver too, so got all the plugs now too. If your wondering what the actuator thing is on the right hand side, see this thread. Hope this helps.
