Author: Subject: Servicing a Seven - Checklist
gingerprince
posted on 30/7/07 at 04:07 PM Reply With Quote
Does anyone have a comprehensive checklist of things to check/service on a seven from a servicing perspective? Of course there's oil/filters/plugs/fluids/pads etc but other things such as greasing bits, checking certain things etc etc.
I assume garages have a "standard checklist" of stuff to do on "major" and "minor" services for standard cars, but wondered if someone had created anywhere a more specific seven/kit car version?
Would be nice as a general "make sure I don't forget anything" tool, but also for documentation of service history etc.
Thanks, Sy
Hellfire
posted on 30/7/07 at 04:57 PM Reply With Quote
We have a checklist to ensure all critical components are checked, nuts and bolts are tight and fluid levels topped up before doing a trackday. We usually spend a few hours going through the list a day or two beforehand and tick them off as and when checked/completed.
Phil
Danozeman
posted on 30/7/07 at 08:09 PM Reply With Quote
I would say
Check suspenion for wear and shocks for leaks.
Check tightness of all suspension and steering bolts.
Change oil and filter.
Change/clean air filer.
Check/change fuel filter.
Check body work is attached ok.
Check under bonnet levels.
Check for leaks and any pipes/hoses chaffing.
Check brakes for wear, leaks and adjustment.
Check tyres pressures and tread and wheel tightness.
Dan
RazMan
posted on 30/7/07 at 10:31 PM Reply With Quote
Also check wheel bearings for play
Raz
gingerprince
posted on 31/7/07 at 02:07 PM Reply With Quote
Originally posted by chris mason
what about checking the cables
Chris
These yours? VVVVVVV
What about presumably less frequent things like diff oil, prop uv greasing? wheel bearing regreasing? given the low mileage of these things are they "once in a blue moon" or still every 12 months or so? what i'm concerned about is missing those "little easy overlooked but important" things.
ta, sy
