chrsgrain
| posted on 13/8/07 at 05:14 PM |
Newly rebuilt engine smokin'
Hi all,
how long should a newly rebuilt engine (red top if it matters) smoke for? Been running for about 10 minutes in total and is still smoking white - when
should I get worried??
Chris
DIY Si
| posted on 13/8/07 at 05:21 PM |
Are you sure the timing's right? I had this once on an A series, and a slight tweek of the dizzy sorted it all out.
Sun Tzu, The Art of War
speedyxjs
| posted on 13/8/07 at 05:38 PM |
Run fuel system cleaner through. Its available from halfrauds
Fatgadget
| posted on 13/8/07 at 05:47 PM |
Ummm white smoke? Doesnt that usualy indicate steam?
scottc
| posted on 13/8/07 at 05:52 PM |
When I rebuilt the 924 engine, well top of the engine, It smoked for about 30 minutes. I didn't think it would ever stop. But it did.
I even went as far as making sure there was no water i the exhaust.
I assume you're not losing water?
chrsgrain
| posted on 13/8/07 at 05:57 PM |
No water loss - the 30 minutes sounds good, need to run it for another 20 at least then!
The run to SVA will take about an hour, so that should sort it out - if we go, ridiculous weather tomorrow means might have to give it a miss..
CHris
andyharding
| posted on 13/8/07 at 06:50 PM |
You only have 10 mins on the engine and are going to drive an hour to SVA? You are a brave man!
I put 100 miles on the clock before my SVA to make sure nothing was going to fall off. All on private roads of course
Are you a Mac user or a retard?
dave r
| posted on 13/8/07 at 08:38 PM |
mine did nearly 2 hours to sva, with no real running prior to that...
i did have a backup vehicle following me though with a trailer!!
dave
whitestu
| posted on 13/8/07 at 08:50 PM |
My first drive was to its SVA. Not very far but it was round the North Circular at 08:00.
No back up.
Stu
[Edited on 13/8/07 by whitestu]
| posted on 14/8/07 at 06:06 AM |
find out what the smoke is.
get a glassd of very cold water and place it at the exhaust; the smoke should condense and then you can smell it to narrow down what it can be:
petrol, water or oil.
leave the engine on idle for 20 or more minutes until it has fully warmed up and the stuff should disappear - hopefully it is just crud in the
exhasut burning off.
check your oil and water levels afterwards.
don't worry about driving to SVA - I did a few pratise runs on the private roads near my house, nothing major - just to test the brakes.
NS Dev
| posted on 14/8/07 at 11:41 AM |
Don't worry chris, my XE's always steam for a good while.
Run it until the fan kicks in, if its still steaming then its more of a worry.
NS Dev
| posted on 14/8/07 at 11:44 AM |
mine ran about 10 mins before sva and about 2 miles!
chrsgrain
| posted on 14/8/07 at 12:21 PM |
Cheers for that Nat.... will have more time to let it run preSVA as the alternator packed up and had to be changed - meant I missed the test though
Chris
thomas4age
| posted on 15/8/07 at 05:20 AM |
smoking doesn't usually stop before the engine is completly warmed up about 20 min idle or 10 minutes drving around town, after I've
replaced a headgasket.
don't strees the engine for the first few runs though otherwise the gasket will go pop again, learned that the hard way!
grtz Thomas
[Edited on 15/8/07 by thomas4age]
If Lucas made guns, Wars wouldn't start either.
