Author: Subject: Cooling
fideel109
posted on 14/8/07 at 08:21 PM Reply With Quote
Cooling
Hi,
I've got some cooling questions.
I've build an Avon (Zetec 2.0) with the standard Tiger radiator.
Is it worth changing it for a VW Polo radiator (has it enough capacity)?
And secondly, how do you connect them?
The Polo radiator has only two inlets, and no connection for the tube coming from the expansion bottle.
The Tiger radiator has 3 inlets and the Polo 2?
rgds-JP
cadebytiger
posted on 14/8/07 at 08:49 PM Reply With Quote
hey there.
i have a tiger cat E1 and recently had a radiator leak.
I was thinking about changing to the polo radiator but in the end got y tiger rad fixed (this was mainly because i knew that it worked). A few things i have noted during my expedition. lol
Many people will say the polo radiator is better as it can be mounted upright - many things i have read have said that infact the radiator should be mounted at a slight angle for most efficient cooling (provided that there it is well boxed in the nose cone).
you are right the polo rad only has two outlets and you must find a T-piece to split the bottom hose.
I think it also has a small breather pipe at the top which must be connected.
An advantage is that it is aluminum of course and there have been some criticisms of the workmanship of the tiger rad.
Not having used the polo i have no idea which is best. i expect that both function perfectly well.
I hope this helps in some way.
The best place the tiger people think to get the rad from is northern radiators i think.
http://www.radiatorsonline.co.uk/
designer
posted on 15/8/07 at 07:11 AM Reply With Quote
I the cooling system works, why change it??
fideel109
posted on 15/8/07 at 08:02 AM Reply With Quote
I'm not so happy with my present radiator (small waterleak), so I'm looking for a way to improve it.
I can get hold on a Polo radiator.
Rgds-JP
saigonij
posted on 15/8/07 at 09:27 AM Reply With Quote
tiger sell a bottom ali pipe with two take offs for the zetec. i think you would use that.
i brought one from them last week.
