rpsmith
| posted on 15/8/07 at 12:16 PM |
Pinto Oil Pump Removal
What is the correct socket / tool to remove the oil pump from a Pinto engine, in the Haynes manual it says use a suitable splined socket, but i tried
my range of Torx sockets and none seemed to be the right size, i tried the nearest size but it just slipped and removed a couple of the slines from
the bolt
Fatgadget
| posted on 15/8/07 at 12:48 PM |
Spline and torx are completely different. Should be able to get a suitable spline tool from Halfrauds if you mention what it's for.
flange nut
| posted on 15/8/07 at 12:57 PM |
IIRC what you need is a M6 spline bit.
Geoff
rpsmith
| posted on 15/8/07 at 01:40 PM |
Ahhhhhh, cheers guys
