oadamo
| posted on 15/8/07 at 05:31 PM |
mot and exhaust
hi i want to run just the cat and no boxes on my audi 1.8t engine do you think it will pass the mot like this.
adam
DIY Si
| posted on 15/8/07 at 05:37 PM |
It's quite likely to be a bit loud. Which can cause a fail. Otherwise, no real issue.
Sun Tzu, The Art of War
SeaBass
| posted on 15/8/07 at 06:06 PM |
Since when can noise affect a car MOT?? Not to my knowledge. The test is simply for blowing on the exhaust IMHO.
Ratters
| posted on 15/8/07 at 06:13 PM |
I think it can be failed on noise but at the testers descretion if it is excessively noisy. I wouldn't imagine it would be a
problem though.
DIY Si
| posted on 15/8/07 at 06:20 PM |
IIRC it can be a fail, but as said above, only at the testers discretion. So he may have a go at you, but not actually fail.
| posted on 15/8/07 at 06:31 PM |
Car CAN fail if fitted with an exhaust that in the testers opinion is louder than normal.
oadamo
| posted on 15/8/07 at 07:17 PM |
ill have to slip the tester some cash then .
adam
bigrich
| posted on 15/8/07 at 09:04 PM |
section 7.1 of the testers manual
b. a silencer in such condition, or of such a type, that the noise emitted from the vehicle is clearly unreasonably above the level expected from a
similar vehicle with a silencer in average condition.
adam try a fiver under the handbrake lever,saves the embarrasment of offering the cash LOL
jollygreengiant
| posted on 16/8/07 at 03:56 AM |
Didn't even get as far as offering a lost note once. Pulled up outside the testing station (which had all its doors shut), the tester came
outside, looked at me & asked if I had brought it down for test. I said 'Yes', he replied FAIL and went back inside shutting the door
as he went.
DIY Si
| posted on 16/8/07 at 06:28 AM |
What had you done to wee him off? Even complete sheds of mine have at least had a once over before failing!
