Author: Subject: Engine number
Dusty
posted on 21/8/07 at 10:37 PM Reply With Quote
Engine number
Just bought a replacement phase 2 silvertop zetec from the local scrappy as my current engine has a vibration at 3000rpm which I have failed to cure.
Engine number on the left block to bellhousing web is a poorly stamped 666666. No NGA as there should be and there should only be five numbers. Wrongly stamped replacement or what? Anyone any ideas? Have I been had?
big_wasa
posted on 22/8/07 at 05:44 AM Reply With Quote
Few of Fords replacement engines get there numbers transfered
Time is money for a garage and its a short cut that Jo punter wont see in his tin top.
Ive had three with no numbers at all, Talking to a guy last night and his was slapped on the head just above the thermostat.
Would doubt its dodgy unless there are signs of grinding to the block imho.
posted on 22/8/07 at 08:04 AM Reply With Quote
I would be very careful about fitting that engine as from the number it looks to be possed.
Marilyn Manson stamped the first 666 and Ozzy Osbourne the other 666; I would expect neither to have been a careful previous owner.
(unless you read it upside down in whcih case it is ok).
