Author: Subject: Weber DGAV
paulbeyer
posted on 8/6/02 at 02:02 PM Reply With Quote
Weber DGAV
Hello girls,
I've just picked up my 2.0L Pinto and with it was a DGAV carb. Is this worth reconditioning? (there's a good place in Bristol that can do it) or is this carb a load of cods bollocks?
David Jenkins
posted on 10/6/02 at 08:00 AM Reply With Quote
Paul,
If it's a 32/36 DGAV then it will probably serve you well enough until you get your twin horizontals!
If you don't fancy using it, pass it on to a X-flow user as it's ideal for those who don't mind a hole in the bonnet (it's what I'm using).
If you're reasonably good with your hands and careful, you can overhaul the carb yourself - Weber sell an overhaul kit of rubber bits and gaskets. That, plus a can of carb cleaner, and you can bring it back to life. The only things that can't be fixed easily are the bearings for the venturi butterflies - if they rattle when you waggle them, get another carb (air gets in and it screws up your settings). Everything else is fixable.
JohnFol
posted on 13/6/02 at 07:12 PM Reply With Quote
Paul, did you ever make use of it?
paulbeyer
posted on 14/6/02 at 12:37 PM Reply With Quote
John,
I've only just got hold of it, so I haven't decided what route to take yet.
