wyatt
| posted on 28/9/07 at 03:01 PM |
Cross flow to BEC
has any one converted from a Ford CrossFlow to a BEC
www.bynxy.co.uk
locoR1
| posted on 28/9/07 at 03:05 PM |
Changed mine about three years ago! 1700 Crossflow to 4xv R1, Now its turbocharged as well
Best thing I ever did to it
Dave............
[Edited on 28/9/07 by locoR1]
Check out my CB500T Cafe Racer build diary
nitram38
| posted on 28/9/07 at 03:35 PM |
locoR1, how much did it cost to go turbo including all parts?
Cheers Martin
locoR1
| posted on 28/9/07 at 06:20 PM |
Cheers Martin
I stopped counting when it got expensive! But it could certanly be done for under £1000 for a basic setup if you wasnt bothered how pretty it all
looks!
I made a few bad choices and had a few problems main one was using a second hand turbo then spending most of the summer trying to stop it smoking !
Now replaced with a new one and it hasn't used any oil in 500miles.
P.s I've been watching you car come together, to say I'm impressed would be an understatement! Cant wait to see it finished!
Dave.........................
Asterix
| posted on 28/9/07 at 07:53 PM |
did more than contemplated this...i have a 919cc blade engine, exhaust manifold, dynojet and clutch cables sitting in my garage currently unused.
Aint 53.78/ Cadw 96.39/ Crof 97/ CurbL1 37.01/ CurbL2 81.? wet/ Heth 82.34 kaput/ Loto tba/ Shel 41.4 wet/ Thor 56.36/ Tycr 129.52
Sponsors... Pets Testing
Webhosting
nitram38
| posted on 29/9/07 at 04:58 AM |
Hi, thanks for the compliments and the info. Looking at certain turbo systems means that because of their position, I would have to alter my chassis
to allow for it.
The other option is a supercharger, but the kits I have seen cost £2700
wyatt
| posted on 1/10/07 at 01:57 PM |
locoR1
what rear axle did you use
www.bynxy.co.uk
locoR1
| posted on 1/10/07 at 05:20 PM |
quote: Originally posted by wyatt
locoR1
I'm using a english live axle 3.54 ratio diff which is ok for a bec!
Although I'm changing it to a de-dion over winter with a 3.38 or if I can find one a 3.14diff.
| posted on 1/10/07 at 09:42 PM |
i did the crossflow to bec swap last year. Very easy really.
I identified on the existing wiring the 'running live' and the 'cranking live' under the bonnet, so i didnt have to mess about
under the dash. Then modifed the bike loom to work from just 3 connections, earth and the two lives above. The chassis mods were very easy. Not much
more to it than that!
wyatt
| posted on 4/10/07 at 10:28 AM |
what prop shaft and axle did you use
www.bynxy.co.uk
