Author: Subject: tin top question
eccsmk
posted on 24/11/07 at 10:51 PM Reply With Quote
tin top question
the car is a mk 2 golf gti 8 valve
its just had full engine rebuild and the problen we are having is the oil pressure is far too high
the gauges are on the head and the oil filter housing and are both reading 80 psi on tickover and 120 psi at 2000 rpm
please can anyone shed any light
thanks in advance
posted on 24/11/07 at 10:54 PM Reply With Quote
Stuck oil pressure relief valve for sure.
NeilP
posted on 24/11/07 at 10:55 PM Reply With Quote
If you're lucky a stuck relief valve - Look it up in the haynes manual.
If you are unlucky a blockage somewhere in the flow lines from the pump to critical parts
If you pay peanuts...
Mentale, yar? Yar, mentale!
Drive it like you stole it!
eccsmk
posted on 24/11/07 at 11:06 PM Reply With Quote
changed the pump tonight and its the same because we also thought it was relief valve
posted on 25/11/07 at 10:22 AM Reply With Quote
Is the gauge you are using a known good one ? or are you using two seperate gauges?. Suspect if oil galleries are blocked there would be no oil supplied to whatever the gallery supplied? also even if there is a blockage oil pressure relief valve should open and drop to correct pressure. The whole point of the relief valve is to limit pressure. Open up the relief valve and check that the valve has not stuck . Unlikely with 2 seperate pumps but faulty parts are not impossible
eccsmk
posted on 25/11/07 at 10:47 AM Reply With Quote
one gauge is new the other is one we have been using on another car for a few years we have swapped thses with 2 more just to make sure it wasn't faulty gauges
we tried relief valve's on both pumps and both were fine off the car so i think it's time to strip it down.
omega 24 v6
posted on 25/11/07 at 11:32 AM Reply With Quote
Did you build it yourself??
Could be shells in the wrong way round blocking the oil feed holes. Drop the sump and check first before a full head strip.
britishtrident
posted on 25/11/07 at 03:52 PM Reply With Quote
It can only be a stuck pressure relief valve or dodgey gauge.
The relief valve controls the max pressure in the system.
[Edited on 25/11/07 by britishtrident]
[/I]
eccsmk
posted on 25/11/07 at 04:23 PM Reply With Quote
both pumps have been tested today and yet another gauge tried and it's still the same
im guessing we will just have to try mains then its head off time
just to add the engine was built by the same person who has build about thirty others for us.
thanks folks
