Author: Subject: Fuel cut-off thingy
David Jenkins
posted on 26/11/07 at 10:36 AM Reply With Quote
Fuel cut-off thingy
A quick question - I'm shortly going to be fitting an electric fuel pump to my locost, and it seems like a good idea to fit a gizmo that'll cut the power to the pump in case of an accident.
Can anyone recommend a suitable donor for one of these? Ideally from a commonly-available vehicle, and easily accessible so the moron from the scrapyard won't throw a sulk.
Presumably it should be mounted securely onto the chassis - I was thinking about putting it just in front of the scuttle. Does this sound right?
cheers,
GeoffT
posted on 26/11/07 at 10:48 AM Reply With Quote
Usually a few of these on ebay, like this :-
Inertia switch
......might save the unpleasant scrapyard visit
Edited to say that mine is simply mounted on the scuttle panel. Fortunately haven't tested it in anger yet, but I'm sure it's solid enough to trip in any significant 'bump'
[Edited on 26/11/07 by GeoffT]
JAG
posted on 26/11/07 at 11:31 AM Reply With Quote
...or you can get the same switch out of a Rover 214/216. It's fitted inside the centre console just below the radio on the drivers side.
Remember to pull the loom through and cut it off about 12" from the plug and you've got everything you need.
I mounted mine to the scuttle, on the engine side. It's nice and easy to get at if you need to reset it.
My cars done almost 7000 miles and I've never had to touch it. And 'yes' it does work, I have tested it but had no trouble with it.
Justin
David Jenkins
posted on 26/11/07 at 12:29 PM Reply With Quote
Two good suggestions - many thanks!
saigonij
posted on 26/11/07 at 01:28 PM Reply With Quote
i got mine on ebay ( item number 270154862031 ).
goes the job. think i mounted mine upside down ( not that i think it matters ) behind the dash - easy to reset.
if its wrong, ill put it button side up, but i think its ok...
NS Dev
Ford sierra injection, in boot under spare wheel.
posted on 26/11/07 at 02:25 PM Reply With Quote
a locost one would be to wire the pump up to the alternator output - obviously you would have to ensure any accidents end up with the eninge not running
martyn_16v
posted on 26/11/07 at 03:36 PM Reply With Quote
If you wired it up to the alternator output it'd probably never start after being left off overnight, the fuel pump needs to prime the fuel system before/during cranking. And you'd need to be able to isolate the alt output from the battery when the engine stops, which is going to be a bit more difficult than just fitting an inertia switch I reckon.
hector
posted on 26/11/07 at 04:44 PM Reply With Quote
I went to me local scrappy and got a mondeo one for 2 quid-Ideal
Wired into pump relay, job done!
Mondeo ones are located in pass footwell on l/h side easy to get at
cheers colin
John Bonnett
posted on 26/11/07 at 06:32 PM Reply With Quote
The problem with buying a Ford switch on its own is that you then need the mating electrical plug to go with it. The spacing of the three connectors is too close for Lucars. This was what I did. I then went to our local scrapyard and found one on a Fiesta located behind the upholstery in the n/s footwell. I bought another switch with the plug and wires for a couple of pounds.
Anybody want a switch on its own??
Mine is mounted on the scuttle through a relay.
NS Dev
posted on 26/11/07 at 08:22 PM Reply With Quote
John's dead right, but on the sierra you just cut the plug off with the switch, problem solved!
GeoffT
posted on 5/12/07 at 10:20 AM Reply With Quote
Not sure if you've found one yet, but I'm using one of these :-
Link
.......works fine and has given no problems so far.
thomas4age
posted on 5/12/07 at 06:51 PM Reply With Quote
I have it wired via an oil presure switch,
the pump goes live in two situations, cranking via the starter relais and via the oil presure switch, in all other cases the pump stops.
you could serie that with a sierra inertia switch to be dead sure nothing goes wrong,
I like the fuel cut option when out of oil presure, it saved me the old 16v engine 2 times.
grtz Thomas
If Lucas made guns, Wars wouldn't start either.
David Jenkins
posted on 11/1/08 at 04:28 PM Reply With Quote
A thought - is a relay necessary with these cut-offs?
Just that I could fit one easily if it's wired in direct, but adding a relay would be a PITA - obviously not impossible, but a real pain.
GeoffT
posted on 11/1/08 at 05:15 PM Reply With Quote
Hmm....you've got me slightly worried now. My cutoff IS wired directly in series with the fuel pump, and I've had one or two instances of the pump being reluctant to fire up at switch on. I'd forgotten this little device was in the circuit, so your post may have pointed me in the right direction.......
All of which is of no help to you at all really....
Geoff.
NS Dev
posted on 12/1/08 at 10:19 PM Reply With Quote
dunno about the rover switch but the one in the sierra boot is direct switching, no relay.
David Jenkins
posted on 13/1/08 at 09:36 AM Reply With Quote
Excellent - looks like I need a Sierra switch then - are the more modern Fords the same? Sierras are getting like hen's teeth these days...
cheers,
britishtrident
posted on 13/1/08 at 10:04 AM Reply With Quote
On most injection cars they are wired through the main relay so they kill the spark as well.
All the Rover ones are fitted where Jag described --- I assume RHD Hondas are the same.
Jag ones are fitted in the boot similar to the Sierra.
Freelander ones are in the engine bay on the scuttle.
[/I]
David Jenkins
posted on 13/1/08 at 11:07 AM Reply With Quote
Stop it!
Every time I think of ways of setting up this switch, somebody thinks of a good idea that changes everything!
Only joking... but that does seem like an excellent idea - it would be very easy for me to cut the feed to the Megajolt, EDIS and coil as they have a common 12v supply.
Looks like a relay is a sound idea - I'll just have to grin and put up with the extra effort it will require (I would want to put the relay in the spare socket on my combined fuse and relay box - I don't want yet another relay screwed to the firewall!)
cheers,
