Mr Clive
| posted on 11/12/07 at 01:07 PM |
Blacktop Zetec Sump
Hi
I have been trawling the archives and im a bit confused (too many threads called "zetec sump" )
Will the sump from a 1.8 phase 1 zetec silvertop from an escort fit onto a 2.0 blacktop from a focus?
If so, are any extra parts required (pickup pipe, windage tray, crank scraper)?
[Edited on 11/12/07 by Mr Clive]
r1_pete
| posted on 11/12/07 at 05:08 PM |
Yes the silvertop sump will fit the blacktop, also needed is the oil pickup to match the sump and the silvertop sump gasket. I don't know
whether the windage tray from the silvertop will fit, or whether there is any experience out there of running without one.
Im just out from having surgery and will be undertaking a similar swap when I can get out into the workshop again....
Regards.
Pete.
Mr Clive
| posted on 12/12/07 at 12:44 PM |
Thanks, thats good to know.
Mr Clive
| posted on 12/12/07 at 01:14 PM |
I found this website http://www.westfieldbuild.net/sump.php
It looks like the windage tray will just bolt on, but it shows there may be a few other problems that need considering
r1_pete
| posted on 12/12/07 at 04:59 PM |
Looks like 4 big end bolts from the phase 1/2 are also needed to bolt the tray on...
Mr Clive
| posted on 12/12/07 at 06:17 PM |
Yeah, the starter motor looks to be the biggest issue though.
r1_pete
| posted on 12/12/07 at 08:04 PM |
Just needs the webs cutting off the sump and a flat plate welding in, I've already modded the phase 3 sump - see photo archive. But the mondeo
rear well sump will suite the MGB I'm putting it in better.
My starter is a QS1220 from QX Components.
