Author: Subject: ecotec distributorless ignition with megajolt?
blakep82
posted on 17/12/07 at 11:35 PM Reply With Quote
would this be easy enough to do? or it the system used by ford and mega jolt different to the GM system?
picked up my engine on saturday, looks very nice
________________________
MikeRJ
posted on 18/12/07 at 08:33 AM Reply With Quote
You can't use the existing trigger wheel on the Ecotec, you'd have to but a 36-1 trigger wheel on the crank pulley. However it's perfectly doable apart from that.
martyn_16v
posted on 18/12/07 at 10:14 AM Reply With Quote
You'd also still have to source a Ford EDIS unit, and check that the specs of the GM coil pack are sufficiently similar to a Ford unit to be useable (although I've got a suspicion they are).
