Author: Subject: V8 EFi wiring.....HELP!!!!
marcjagman
posted on 13/1/08 at 04:28 PM Reply With Quote
I have a 3.5 efi V8 from a 1987 range rover, it can with wiring and ECU, any ideas how I wire it up so it will run? any pointers welcome as I don't fancy paying out for new carbs etc. By the way I'm crap at electrics so please try and keep it simple.
mark chandler
posted on 13/1/08 at 05:32 PM Reply With Quote
Its really simple..... Yes it is if the loom is complete, three wires only required + coil input.
You should have a load of wires with plugs that go around the engine, from this lump 1 single wire that goes to the coil.
Half way back a large plug that the resistor pack goes into and a multiplug, then at the far end a few relays and the ECU.
On the multiplug mentioned above you need a continous live, switched live and earth, Bob's you uncle and fanny's yor aunt !
I cannot remember the pinouts on the multiplug, a red and a couple of whites maybe.... have a look at a wiring diagram.
Regards Mark
marcjagman
posted on 13/1/08 at 05:55 PM Reply With Quote
Thanks, I think, been trying to find a wiring diagram online but no luck yet
