Author: Subject: Bolt sizes again, exhaust manifold to Crossflow head
ironside
posted on 13/2/08 at 07:04 PM Reply With Quote
Hi,
Can anyone tell me the thread size for bolting the exhaust manifold to a Crossflow head? My donor had a few bolts missing.
Thanks,
Simon
posted on 13/2/08 at 07:14 PM Reply With Quote
IIRC the head is tapped 5/16"UNC the studs are threaded 5/6"UNF on the outer end and normally use brass nuts. Burtonpower stock the studs and nuts.
procomp
posted on 13/2/08 at 07:19 PM Reply With Quote
Hi Simon. Yep the above is correct. Now if i had known i could have put a set in with the other bolts.
Cheers Matt
ironside
posted on 13/2/08 at 11:54 PM Reply With Quote
Thanks to you both.
Matt, if I had known I would've mentioned it! I always discover I need something else right after somebody has sent me something or I've ordered it.
