Dave Bailey
| posted on 16/2/08 at 08:57 PM |
Sierra Diff
On a Velocity XT the lower mounting bolt cannot be fitted or removed without removing one of the lower wishbones. To prevent having to do this I
thought maybe tapping and helicoiling the diff flanges then using two bolts would be o.k. Anyone else done this?
thanks
Dave Bailet
TimC
| posted on 16/2/08 at 09:06 PM |
Standard procedure for an MNR. Go for it!
| posted on 16/2/08 at 10:05 PM |
How often do you expect to be removing the diff? Considered doing it on mine but thought better of it.
Dave Bailey
| posted on 16/2/08 at 10:58 PM |
Hi..point taken on removing the diff but In the job I have we are always focused on making things easily maintainable where possible. This is one such
case!
Dave B
tomblyth
| posted on 17/2/08 at 10:48 AM |
Tap a piece of tube and use two bolts one from each side this would allow easy out and mean no alterations to the replacements diffs in the future!
bill132hotrod
| posted on 17/2/08 at 11:16 AM |
Diff
I was talking to Ben at luego a few weeks ago about this same problem and he assured me that this was (1) of the many faults that i have found with
his product that they are addressing along with the developement of there new chassis.
saigonij
| posted on 17/2/08 at 12:37 PM |
its not too much of a problem.
if you want to remove the diff, simply take the two inbound lower wishbone bolts out, and then swing the lower wishbone upwards a bit - just enough to
take the DIFF bolt out.
dont it on mine a few times...
