:{THC}:YosamiteSam
| posted on 19/2/08 at 10:20 PM |
temp gauge
just doing some prelim wiring - zetec silver top 1.8.. one question..
ecu needs a sensor to tell it the water temp - use the themostat housing connection on the top - so where does the engine temp gauge connection go?
double up to the same connection? if the ecu is being told the temp it will do for the gauge - am i right? i have seen the ally connectors for the top
hose where a probe is inserted to for it - is that the only option? more money???????? lol ???
also sorry second question what is the lower connection for on the thermostat housing?
cheers guys
| posted on 19/2/08 at 10:55 PM |
Zetec thermostat has the big sensor on the top I believe is for the ECU and a smaller one on the side for the temp gauge...
Thats what mine looks like anyway
saigonij
| posted on 20/2/08 at 08:30 AM |
thats correct.
:{THC}:YosamiteSam
| posted on 20/2/08 at 05:47 PM |
cool - will now try to source a plug for it.. anyone know where i can get one??????
paulf
| posted on 20/2/08 at 06:57 PM |
You must use the lower sensor for the gauge, dont try and run gauge and ecu from the same sensor as it will cause them both to work incorrectly.
I think the lower sensor is just a spade terminal, if not a local scrapyard is the easiest bet.
Paul.
