dave1888
| posted on 22/3/08 at 04:02 PM |
Gravity fed carbs
I have been informed that my daytona carbs are gravity fed, what happens if you use a R1 fuel pump to feed them. I dont have a regulator fitted.
r1_pete
| posted on 22/3/08 at 04:17 PM |
As long as its a carb R1 pump NOT an injected pump, you'll be ok. These pumps only deliver 3 or so PSI, you might find the carbs have a bigger
bore feed pipe than pumped carbs.
snapper
| posted on 22/3/08 at 07:14 PM |
Either gravity feed them with the correct pipe diameter or use what you have and fit a regulator for not much squids so you can fine tune the fuel
delivery.
It really is fundamental, the carbs need the design fuel delivery pressure and volume or they will not work properly.
I eat to survive
I drink to forget
